Amazon Fire HD 8 Screen Replacement
Выберете то, что вам нужно
  1. Amazon Fire HD 8 Screen Replacement, Screen: шаг 1, изображение 1 из 2 Amazon Fire HD 8 Screen Replacement, Screen: шаг 1, изображение 2 из 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Screen Replacement: шаг 2, изображение 1 из 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Screen Replacement: шаг 3, изображение 1 из 3 Amazon Fire HD 8 Screen Replacement: шаг 3, изображение 2 из 3 Amazon Fire HD 8 Screen Replacement: шаг 3, изображение 3 из 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Screen Replacement: шаг 4, изображение 1 из 3 Amazon Fire HD 8 Screen Replacement: шаг 4, изображение 2 из 3 Amazon Fire HD 8 Screen Replacement: шаг 4, изображение 3 из 3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
    Hello,
    I followed this tutorial, and it was very helpful. However, the screen does not react to touch. Its there some sort of hard reboot required? Or is my problem likely a screen malfunction problem?
    Thanks,
    Keegan Fregeau - Ответить
    Hi Keegan.  Did you ever get a response to your question on this?  I just replaced my screen on a kindle fire hd8 today and am having issues with the touch screen.  it turns on and apps come up but when I try to enter a passcode certain numbers won’t populate and certain areas of the screen won’t respond.  It’s very touchy in some areas and not so much in others. :(
    Cheryl Waltz -
    Mine is doing that NO response thing also. Have inspected for any tiny hsrd to see damages. Looks perfectly fine. Why it no response now?
    Kitty Morgan - Ответить
    I think no one has an answer for why the touch screen doesnt feel touchy any more after a quick freedom from attachment time. Maybe that super tough sticky adhesive,once its been conquered successfully, lets the magic touch electrons escape from the screen so it doesn’t recognize the touch as completing the circuit. Any ideas on that? I’ve heard of the smoke theory before, but no smoke escaped that was visible. And the Olofonz Theory, that I learned a bunch of years ago in the USN, doesnt apply to this mystery either. Anybody out there? Please, ET geeks, I need some help so I can grow my skill levels higher to prevent the total destruction of my budget by replacing one cell phone, or tablet, right after another. Ouch!
    I’m confused, other videos online give the suggestion that to remove the screen is a longer process. Also the pictures don’t appear to illustrate the actual glass being removed, between step 3 & 4 the glass cover has disappeared and there’s no mention of it.
    Steve Chapman - Ответить
    You will need to reheat the screen so it can adhere to the LCD.
    cl0udwatcher - Ответить
    I'm having a similar issue with the touch screen not responding to touch, Hadn't used it in 2 months since my son got sick all over it and it didn't seem to want to charge or hold a charge after cleaning and drying it up,.. until today I decided to check it out, which it was able to charge and powered on, which soon after jumped to 9% charge then 50%, I checked to see if there was a new system update, which there was one downloaded/ready to install and one pending or something like that and it mentioned that it would auto install the next time the Kindle wasn't in use or I could choose to update now, clicked now to get it over with and ever since the screen has been non responsive. now the screen will come on but I am unable to slide unlock or press anything, I can hold the power button and the option pops up to restart or turn off and I can't select either,… the volume buttons work, and the power button, which I've tried the “hold the power button for 40seconds “ to restart but it doesn't help…..
    I'm lost….
    tripnoticntx - Ответить
    I read from another site that you should disconnect the battery not just power off and to also ground yourself or get a grounding strap from a electronic supply place do that you do not short anything out. I have not done mine yet I am still researching. I will send a link if I can find a good one . Thanks for the warnings.
    imememine - Ответить
    I just successfully replaced the glass and digitizer on a Kindle Fire HD 8 Plus 10th generation (as a complete novice). This is NOT all it took. The digitizer has to replaced and the glass replacement should come with that attached. It has to be threaded through and carefully inserted into the port. There were no instructions that came with the kit I ordered off Amazon for $26.99 and no videos of the 10th generation model. I watched some older ones…went for it…and it worked!
    best video: https://youtu.be/biasTJcB6GQ
    Amy Bennett - Ответить
Заключение
27 участников успешно повторили данное руководство.
Dan Shimkus
Участник с: 02/24/16
1 184 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 1-3, Leahy Spring 2016 Участник USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 членов
Автор 17 руководств
18 Комментариев
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - Ответить
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber -
Fingers crossed Amazon offers more parts in the future! :)
Kelsea Weber -
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan -
There's a thought i didn't have. I Asked Alibaba if theirs would be compatable. No answer yet. What else goes wrong with them? Who would try and sell a broken one? What do you think about using an iron over a tea towel instead of a heat gun?
Do you know if all the HD 8’s are the same instructions for the screen replacement mine is version 6
john evans - Ответить
Is this the 7th generation fire hd tablet?
Sean Watts - Ответить
You can buy replacement screens on ebay. I got mine for about $12 and it came directly from China.
Bret Essing - Ответить
How did it work out?
Peter Meny -
I worked out great and was shipped directly from China with a lot of padding. The above guide put us in the right direction, however nothing in the guide mentioned having to remove the back cover first. After spending a lot of time doing a lot of the wrong things, we found another kindle guide for a different model that helped get us back on track. Once we had the back off, the rest was a piece of cake. I now have a working HD Fire 8 with a new screen!
Bret Essing -
I've found replacement digitizers on eBay but I can't find a break down of how it is bonded to the LCD. Will I need Loca glue and a UV light? 6th generation HD 8
arosadler - Ответить
Same here. Did you found a solution?
kidkaraoke -
On Monday we are going to be doing a PR53DC Model its the For Amazon Kindle Fire HD 8 HD8 6TH- PR53DC were gonna see if we can do it without breaking the LCD. We will let you know if it needs loca or OCA were hoping its not fused just glued along the edges so we can just slice the adhesive free.
Adrienne S - Ответить
Amazon is selling the screens for the fire hd8
pate7111 - Ответить
can you help me with my amazon
fire 8 tablet
Samantha Lenz - Ответить
With the 7th Gen Fire HD 8, The entire assembly must be removed
David Madrigal - Ответить
Atlanta based Injuredgadgets has screens readily available. They do replacement parts for most handheld electronics, computers, and video game consoles.
Adrian Nelson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 107
За последние 30 дней: 440
За всё время: 68,217
