Введение
If your device is having issues caused by a faulty motherboard, you can follow this guide to easily replace the motherboard.
Выберете то, что вам нужно
Place the plastic opening tool in the space between the rubber and the plastic case of the device.
Apply pressure by pushing upward on the case.
Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
5 участников успешно повторили данное руководство.
