Amazon Fire TV Remote Control Motherboard Replacement
Выберете то, что вам нужно
  1. Amazon Fire TV Remote Control Motherboard Replacement, Batteries: шаг 1, изображение 1 из 2 Amazon Fire TV Remote Control Motherboard Replacement, Batteries: шаг 1, изображение 2 из 2
    • Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
    • Lift the battery cover up to expose the batteries.
  2. Amazon Fire TV Remote Control Motherboard Replacement: шаг 2, изображение 1 из 2 Amazon Fire TV Remote Control Motherboard Replacement: шаг 2, изображение 2 из 2
    • Use your index finger to push the battery back and lift up to remove the battery.
    • Repeat the procedure for the second battery.
  3. Amazon Fire TV Remote Control Motherboard Replacement, Remote Control Motherboard: шаг 3, изображение 1 из 2 Amazon Fire TV Remote Control Motherboard Replacement, Remote Control Motherboard: шаг 3, изображение 2 из 2
    • Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
  4. Amazon Fire TV Remote Control Motherboard Replacement: шаг 4, изображение 1 из 2 Amazon Fire TV Remote Control Motherboard Replacement: шаг 4, изображение 2 из 2
    • Locate the bottom of the remote control.
    • Place your thumb on the bottom part of the remote. Apply pressure as shown in the picture to release the back panel from the front of the case.
  5. Amazon Fire TV Remote Control Motherboard Replacement: шаг 5, изображение 1 из 2 Amazon Fire TV Remote Control Motherboard Replacement: шаг 5, изображение 2 из 2
    • Insert a plastic opening tool in the gap and apply some force to disconnect the two pieces away from each other.
    • Since there are two pins keeping the back of the case together with the motherboard, some force is needed to separate them.
  6. Amazon Fire TV Remote Control Motherboard Replacement: шаг 6, изображение 1 из 1
    • Unscrew the seven 2.4 mm Phillips J#00 screws that connect the motherboard to the case.
  7. Amazon Fire TV Remote Control Motherboard Replacement: шаг 7, изображение 1 из 1
    • Place the plastic opening tool or your fingernail in the gap at the top end and lift the motherboard.
Заключение
5 участников успешно повторили данное руководство.
Alejandro Franco Ceron
Участник с: 09/01/15
739 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 16-3, Wollert Fall 2015 Участник USF Tampa, Team 16-3, Wollert Fall 2015
USFT-WOLLERT-F15S16G3
4 членов
Автор 16 руководств
3 Комментариев
Hello,
step 5 is wrong! There are no pins but screws!
You need to disconnect the upper piece (infrared sensor) first. Underneath you will find two more screws. Then you can open the case easily.
TheAffenkotze - Ответить
The circuit board can not be fixed instead of replaced. Understand might be cheaper to replace
Seymour Butts - Ответить
This was useful to me to find a location I could attach a lanyard to the remote. It is so small it keeps disappearing.
Patrick Kniesler - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 51
За последние 30 дней: 226
За всё время: 12,446
