Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide takes you step by step through the process required to replace the batteries of the Amazon Fire TV Stick remote. This task is simple and should not take more than a few minutes. To complete this you will need a plastic opening tool and two new batteries. If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick.
Запчасти
  1. Use the plastic opening tool to press into the seam between the remote and battery cover. With the same tool to help pop the batteries out. With the same tool to help pop the batteries out.
    • Use the plastic opening tool to press into the seam between the remote and battery cover.
    • With the same tool to help pop the batteries out.
  2. Place two fresh batteries back inside the remote and slide the cover back on.
    • Place two fresh batteries back inside the remote and slide the cover back on.
    • Ensure positive ends of the batteries both point towards the top of the remote.
Заключение
7 участников успешно повторили данное руководство.
Andrew Busse
Участник с: 12.07.2016
714 Репутация
Автор 2 руководств
Команда
IUPUI, Team 2-3, Harley SU 2016 Участник IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 членов
Автор 12 руководств
Комментариев: 29
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - Ответить
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber -
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - Ответить
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Kelsea Weber -
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 28
За последние 7 дней: 205
За последние 30 дней: 1,039
За всё время: 87,251
