Введение
As your Kindle gets older the battery life for it gets worse. This guide will teach you how to replace the battery for your Kindle, so you can enjoy hours of reading without having to charge it as often.
Выберете то, что вам нужно
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
Work your way around the back panel to free all the clips.
There are 5 clips on the long and thickest side of the oasis, and none on the others.
Carefully remove the back panel from the device.
Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
Gently wedge the spudger under the battery starting from the left side, and slowly work the spudger around the edge to loosen the battery from the tape. Be careful not to rip the thin foil on the back of the battery.
Lift the battery up using a spudger and use your fingers to slowly pull the battery off the adhesive.
Once free of the adhesive and connectors, remove the old battery from the device.
Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
18 участников успешно повторили данное руководство.
23 Комментариев
Grate explanation. where can I find the battery? couldn’t find it anywhere
thanks
Hi, same comment: great and interesting but I can’t find the battery anywhere…
You can find the battery here
https://www.nextbatteries.com/products/a...
890 mAH Li-Polymer 3.7V 61.60 x 53.32 x 2.78mm
