Введение
This repair would be necessary if the plastic drive gears within the AmazonBasics stripped, meaning the teeth were either ground down or broke off. A telltale sign of this is if you can hear the motor spinning, but the shredding blades do not move.
Выберете то, что вам нужно
Remove the six 14mm PH1 screws holding the bottom cover in place.
Remove the cover by lifting straight upwards.
Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
5 Комментарии к руководству
Where does one buy these gear parts?
Hi, you can buy the gear here: https://www.ebay.com/itm/116169745117
I need big wheel for Bonsaii C220-A and need a duel gear wheel (1.6 inches and 0.5 inches) Apelila Apelila paper shredder
Send me a message on eBay, https://www.ebay.com/usr/krunkz, I will recreate your damaged gears for free if you can mail them to me.
