Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
Remove the sanding disc from the floor sander.
