Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to remove and replace the handle on the American Sanders EZSand Orbital Sander 07163A.
Выберете то, что вам нужно
Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
Remove the front half of the handle enclosure.
Pull the wires connected to the interlock assembly straight out of their connectors.
After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
Use a 4 mm hex key to remove the two 13.8 mm-long screws securing the green ground wires to the handle enclosure.
Use a 7/8" wrench to loosen the coupling securing the power cord to the handle enclosure.
Use a 3/16" hex key or driver bit to remove the 13.8 mm-long screw securing the rear half of the handle enclosure to the handle tube.
Еще один человек закончил это руководство.
