American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement
Выберете то, что вам нужно
  1. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Separate the handle: шаг 1, изображение 1 из 1
    • Before you begin, make sure the sander is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement: шаг 2, изображение 1 из 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement: шаг 2, изображение 2 из 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement: шаг 2, изображение 3 из 3
    • The rear half of the enclosure is bolted to the handle support, so the front half will be removed first.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Unplug the interlock assembly: шаг 3, изображение 1 из 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Unplug the interlock assembly: шаг 3, изображение 2 из 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Unplug the interlock assembly: шаг 3, изображение 3 из 3
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects on the interlock assembly.
  4. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Remove the interlock assembly: шаг 4, изображение 1 из 1
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
Заключение
Еще один человек закончил это руководство.
Adam O'Camb
Участник с: 04/11/15
196 299 Репутация
Автор 416 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 436
