Введение
No-one likes hot air coming from broken plastic. Use this guide to replace the outer casing of your Andis Fold-N-Go Hair Dryer to keep hot air in a happy home.
Выберете то, что вам нужно
Remove the two Phillips #00 screws:
One Phillips 16mm screw
One Phillips 14 mm screw
Remove the internal components from the rear portion of the handle.
Remove the switch
Remove the circuitboard
Remove the capacitor in black plastic
Remove the lower portion of the handle by sliding the peg out of the slot at the top of the handle.
Еще один человек закончил это руководство.
