Введение
This is a simple guide to remove the battery. This might be needed if your battery is dead and want to replace it.
At the bottom of the camera you will see the battery compartment cover as seen in the picture.
To open this compartment, apply pressure in the direction of the arrow and remove.
You will see the battery being held in place by a clear plastic kickstand.
Use your finger to move the kickstand away from the battery.
