Введение
hello all, today we will try to repair the angelcare baby monitor.
two rechargeable battery's exploded, the acid was around an electric power cable. so there were two problems :
1 bad connection
2 battery damage.
we will check also the second unit.
Инструменты
Запчасти
Детали не указаны.
first remove the 2 screws at the green plastic plate.
remove the plastic plate ( battery compartment)
you'll see that there are 2 more screws. Remove them.
now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
2 battery's were exploded so the acid was on the black electric power wire.
use a cotton swab with a little bit of destilled water.
pull the first PCB up and remove the screws of the second PCB.
after removing the two PCB's, clean the acid on the PCB.
after cleaning the PCB's put it al together again.
first remove the battery lid. 1 screw.
slide it out like you see in picture
remove battery's
6 участников успешно повторили данное руководство.
Комментариев: 11
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene -
If your screen is losing display segments, this guide shows the required repair.
Colin -
Screen repair:
1. Disassemble according to the above instructions. There is no need to take the screen out of its plastic housing.
2. Position the screen so you can see the ribbon coming to it and its contacts. From now on, the screen should not be moved.
3. Use a hair dryer or similar device and heat the PCB at the spot where the ribbon contact cable is attached to the PCB, leading to the screen. Heat it well enough its hotter than you can touch - the plastic on the nearby condensers and other glues should become soft.
4. The screen shall become transparent when hot, and black when getting colder. Worry not.
5. Use a tool to press the ribbon harder onto the PCB.
6. While at it, press with your fingers also where the ribbon enters the screen, I cannot say on which side of the ribbon your problem lies. Both shall be hot, they’re near.
7. Blow some cold air over it, leave it to cool.
8. Assemble it back to the original Step 4, test.
9. Mine works all but the two lower bargraphs!
10. Else, new PU is 36eur.
Hello. Thanks for disassembly hints. I had issue with blank screen. This helped: https://www.instructables.com/Repair-a-M...
HINT: Instead of hot-air gun use hot melt adhesive (https://en.wikipedia.org/wiki/Hot-melt_a...) gun. Just use its hot spike, and you will be able to point precisely to the place you need a heat.
Please, can somebody tellme the Speaker specs , mine got broken and i want to replace it.
