Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
When a battery gets worn out a fresh battery might be needed. A new battery may be needed when the mouse is not working properly or not at all. For the Anker 2.4G Wireless Mouse it only needs 1 AA battery. This guide will say what’s needed to know about a battery replacement for this mouse. While doing this make sure no metal tools are being used because if they touch the battery that could be a hazard. A good way to avoid something happening is using plastic opening tools and spudgers (nylon). This is a very simple and quick repair anyone could do.
Инструменты
Инструменты не указаны.
Запчасти
  1. First, remove the battery cover which you can get off with a plastic opening tool, nylon spudger, or just a fingernail.
    • First, remove the battery cover which you can get off with a plastic opening tool, nylon spudger, or just a fingernail.
  2. Once the cover is off remove the battery. To do this use a finger nail or a nonmetal tool.
    • Once the cover is off remove the battery. To do this use a finger nail or a nonmetal tool.
    • After the old battery is out replace it with one new AA battery.
Заключение
Еще один человек закончил это руководство.
Vincent Lee
Участник с: 23.01.2014
361 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 1-39, Maness Winter 2014 Участник Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 членов
Автор 8 руководств
Комментариев: 2
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - Ответить
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 47
За всё время: 3,925
