Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
A new battery may be needed when the mouse is not working properly or not at all. For the Anker 2.4G Wireless Mouse it only needs 1 AA battery. While doing this make sure no metal tools are being used because if they touch the battery that could be a hazard. A good way to avoid something happening is using plastic opening tools and spudgers (nylon).
Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
Еще один человек закончил это руководство.
2 Комментариев
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
