  1. Use screwdriver to pry off the stickers marked in red to reveal the location of the 4 screws.
    • Use screwdriver to pry off the stickers marked in red to reveal the location of the 4 screws.
  2. Remove the 4 screws to continue.
    • Remove the 4 screws to continue.
  3. Pry the center of the mouse apart to separate the upper and lower housing of the boards. Pry the center of the mouse apart to separate the upper and lower housing of the boards.
    • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  4. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  5. Remove the wires from the white crimp headers. this will separate the upper and lower housing units of the mouse.
    • Remove the wires from the white crimp headers. this will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, being as careful as possible to avoid ripping the wires.
  6. Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place. Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
    • Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
  7. Gently remove board.
    • Gently remove board.
  8. The DPI button is the red push button highlighted in red. To remove it, flip the board over and desolder the wires highlighted in orange.
    • The DPI button is the red push button highlighted in red.
    • To remove it, flip the board over and desolder the wires highlighted in orange.
    • Replace component with new component and resolder back in place.
Заключение
Colin
Участник с: 10.02.2014
349 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 1-39, Maness Winter 2014 Member of Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 12
За 30 дней: 24
За всё время: 2,281
