Введение
This guide shows how to replace the LED on the Anker 2.4G Wireless Mouse. The mouse will stop working if the LED inside stops working. Instead of throwing out a mostly functioning product, simply replace the LED and get the mouse working again.
Выберете то, что вам нужно
Use a spudger to gently pry off the stickers to reveal the location of the four screws.
Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
Take the upper housing of the mouse and remove the two screws that hold the board in place.
