Введение
This mouse was designed with usability in mind taking little to no effort to fix anything.
  1. Use the screwdriver to remove the stickers hiding the screws marked in red.
    • Use the screwdriver to remove the stickers hiding the screws marked in red.
  2. Remove the 4 screws to continue.
    • Remove the 4 screws to continue.
    • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Don't pull the wires too hard, as they might break.
    • Pull the Scroll wheel, in red, to the left to remove it.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    • Replace/clean if needed.
    • If your mouse still doesn't work after this step, please continue onto the next step.
    • Desolder these 3 pins and solder the replacement part in.
Заключение
Vincent Lee
Участник с: 23.01.2014
361 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 1-39, Maness Winter 2014 Member of Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 членов
Автор 8 руководств
Один комментарий
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - Ответить
Просмотр статистики:
За 24 часа: 8
За 7 дней: 34
За 30 дней: 102
За всё время: 4,374
