Anker 2.4G Wireless Mouse Scroll Wheel Replacement
Выберете то, что вам нужно
  1. Anker 2.4G Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: шаг 1, изображение 1 из 1
    • Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
  2. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
  3. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 3, изображение 1 из 2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 3, изображение 2 из 2
    • Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
  4. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 4, изображение 1 из 1
    • Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
    • Don't pull the wires too hard, as they might break.
  5. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 5, изображение 1 из 2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 5, изображение 2 из 2
    • Pull the scroll wheel put parallel to the board.
    • This may take some force to remove. Pull the scroll wheel out parallel to the board rather than perpendicular to it.
    • Replace/clean if needed.
    • If your mouse still does not work after this step, then continue to the next instruction.
  6. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: шаг 6, изображение 1 из 1
    • Desolder the three pins, then solder in the replacement part.
Заключение
Vincent Lee
Участник с: 01/23/14
361 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 1-39, Maness Winter 2014 Участник Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 членов
Автор 16 руководств
Один комментарий
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 12
За последние 30 дней: 55
За всё время: 8,423
