Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
Pull the scroll wheel put parallel to the board.
Replace/clean if needed.
If your mouse still does not work after this step, then continue to the next instruction.
Desolder the three pins, then solder in the replacement part.
Один комментарий
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
