Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Use a pry tool or your screwdriver to carefully pry off the stickers marked in red to reveal the location of 4 screws.
Use a flat head screw driver or iFixit guitar pick to carefully pry apart the upper and lower housing of the mouse. Make sure you aren't putting too much pressure, as you could warp the plastic.
Pull the wires from the white crimping headers to disconnect them, separating the top from bottom.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Lift the motherboard gently away from the plastic housing.
The IC (Integrated Circuit) is highlighted in red, it is the mouse sensor.
Desolder the 6 wires holding the IC in place to complete the sensor change.
Replace component with new component and resolder back in place.
2 участников успешно повторили данное руководство.
