Введение
Should your Anki Vector go over any rough terrain or just accumulate wear over time, you will need to replace its belts.
This guide will help you if the Anki Vector’s wheel belts have become visibly damaged or too stiff to allow proper movement.
You will not need any special equipment for this guide.
Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
Repeat on the other side.
Еще один человек закончил это руководство.
Один комментарий
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
