Введение
This guide will demonstrate how to replace the antenna on the Motorola V180.
In order to fix the antenna, you need a replacement antenna. You may purchase one here.
Unscrew your old antenna by rotating the antenna counterclockwise and removing it from the phone.
After removing the antenna, the phone should appear like this.
If it does not look like this, please repeat the previous step.
Insert the new antenna in the hole located at the top of the phone. This hole is where the previous antenna was removed from.
Rotate the new antenna clockwise until it is secured in the hole.
The phone should now appear like this. If not, please review previous instructions.
The installation of your new antenna is now complete.
