Введение
How to open the converter box and replace the power supply...
Запчасти
  1. Unplug your device from the wall outlet.
    • Unplug your device from the wall outlet.
  2. Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
  3. Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
    • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
  4. Locate the power board inside the converter box.
    • Locate the power board inside the converter box.
    • Circled in red in the picture.
  5. Remove this plug
    • Remove this plug
    • You will need to squeeze the locking lever to release it. don't pull too hard.
  6. Remove this plug from the main board. It is not detachable from the power board end.
    • Remove this plug from the main board. It is not detachable from the power board end.
    • Be gentle.
  7. Remove one last cable. This one leads to the front panel
    • Remove one last cable. This one leads to the front panel
    • Be gentle.
    • Circled in red
  8. Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Circled in blue
  9. Remove the four silver colored philips screws holding the power board in.
    • Remove the four silver colored philips screws holding the power board in.
    • Marked in pink (eeww)
  10. Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Here is the empty spot.
Заключение
6 участников успешно повторили данное руководство.
Michel
Участник с: 18.06.2010
288 Репутация
1 руководство автора
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 8,821
