Введение
Instructions on how to replace the camera on the Apex TM772.
Выберете то, что вам нужно
With tweezers or your fingers remove the tape covering the camera’s pin connector.
With tweezers, flip the black latch to open the pin connector and remove the cable.
The camera is adhered to the device with double sided foam tape. Carefully remove the camera from the tape with a metal spudger. If the tape is damaged, you’ll need to replace it.
Replace the camera with the new one and assemble the device in reverse of these instructions.
