Введение
This will be the starting point for any repairs that you may need to do on your Apple AirPort Extreme Model A1143. Some patience should be used when removing the case as it can be fragile.
Запчасти
Никакие детали не требуются.
  1. The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Lift up the back case from the perforated edge to remove it.
    • Lift up the back case from the perforated edge to remove it.
  5. Remove logic board and metal casing from outer case by prying from one side using a spudger.
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
Заключение
2 участников успешно повторили данное руководство.
Zak
Участник с: 23.09.2014
507 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 12-4, Blackwell Fall 2014 Member of USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 2
За 7 дней: 6
За 30 дней: 36
За всё время: 1,842
