Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement
Выберете то, что вам нужно
  1. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Back Pad: шаг 1, изображение 1 из 1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Back Cover: шаг 2, изображение 1 из 1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement: шаг 3, изображение 1 из 1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Remove from Case: шаг 4, изображение 1 из 1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Detach Logic Board From Case: шаг 5, изображение 1 из 1
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Pull Back Tabs: шаг 6, изображение 1 из 1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Remove Metal case: шаг 7, изображение 1 из 1
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Unhooking the WiFi Card: шаг 8, изображение 1 из 1
    • Locate the WiFi card on the logic board, then use the prying tool to bend back the plastic holding it in place.
    • Be careful when prying back the plastic piece, it can break if bent too far.
  9. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Removing the WiFi Card: шаг 9, изображение 1 из 1
    • After holding back the plastic piece keeping the card in place, lift the card up and pull it away from the logic board.
Заключение
Еще один человек закончил это руководство.
Zak
Участник с: 09/23/14
616 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 12-4, Blackwell Fall 2014 Участник USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 членов
Автор 10 руководств
Один комментарий
What types of mini pci wifi cards are supported?
Dan S - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 25
За всё время: 3,068
