Введение
If the base station is sending out a poor signal, an antenna may need to be replaced.
Запчасти
Детали не указаны.
  1. First start by peeling off the outer rubbery covering on the bottom of the device.
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell. It should make a click when it comes apart. It should make a click when it comes apart.
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Remove the outer casing.
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Remove the metal casing by gently prying the logic board away with you hands.
    • Remove the metal casing by gently prying the logic board away with you hands.
    • This should be pretty easy, you already removed the screws holding these pieces together.
  7. Turn the device so that the antenna to be replaced is facing you. Turn the device so that the antenna to be replaced is facing you.
    • Turn the device so that the antenna to be replaced is facing you.
  8. Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
    • Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
    • Using the screwdriver, unscrew the 2.5mm Phillips screw on the antenna.
  9. Turn the device over so that the antenna with the screw removed is still facing you.
    • Turn the device over so that the antenna with the screw removed is still facing you.
  10. Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
    • Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
  11. Carefully peel back the clear yellow tape covering the  cable of the antenna to be removed. Carefully peel back the clear yellow tape covering the  cable of the antenna to be removed.
    • Carefully peel back the clear yellow tape covering the cable of the antenna to be removed.
  12. Remove the antenna.
    • Remove the antenna.
Заключение
4 участников успешно повторили данное руководство.
Brandon
Участник с: 02.04.2012
378 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-2, Forte Spring 2012 Участник Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 членов
Автор 6 руководств
Комментариев: 3
Where do you get a new antenna from?
jimholewka - Ответить
That's my question too. Where do we get a new antenna and wifi card to correct a poor signal?
jonathan - Ответить
How will I receive an answer? jonathan@baylis.ca
jonathan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 29
За всё время: 11,615
