Apple AirPort Extreme Model A1354 Antenna Replacement
Выберете то, что вам нужно
  1. Apple AirPort Extreme Model A1354 Antenna Replacement, Outer Case: шаг 1, изображение 1 из 1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
    By the time I needed to open my AirPort Extreme in mid-2019, the adhesive bond to the covering had weakened to the point that the covering readily peeled away cleanly without the application of heat. I just worked slowly and carefully.
    The covering had no residue of adhesive on it after removal, but there was a sheet of adhesive clinging to the plastic surface of the body of the unit. I had to poke holes in it to reach the screws, but that was no big deal and easily done.
    When finished, the rubbery covering adhered to the body of the unit again adequately without the use of additional adhesive or (as I had planned to use) double-sided tape.
    BTW I was not disassembling the unit to replace the battery, but rather to reset the device by bridging the contacts that a broken reset switch failed to connect. (The switch had become detached from the circuit board and was literally hanging by a thread when I opened the case and fell off altogether as I examined it.)
    Thanks for the clear disassembly instructions!
    gambaguru+fb - Ответить
    When I performed this, the rubber had deteriorated(?) and tore quite easily, particularly around the model number label.
    Steve I - Ответить
  2. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 2, изображение 1 из 1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
    Use a #0 Phillips driver for these screws. Knowing they are 4.9mm is not necessary unless one needs to be replaced.
    Steve I - Ответить
  3. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 3, изображение 1 из 1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 4, изображение 1 из 3 Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 4, изображение 2 из 3 Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 4, изображение 3 из 3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 5, изображение 1 из 1
    • Remove the outer casing.
    • The exposed logic board should look like this.
    Remove the 3 connectors from the logic board to the antennas before removing the logic board from the metal surround.
    Dan McGoldrick - Ответить
    My unit, still A1354, had FOUR antennas. The logic board was labeled 820-2622-A copyright 2009.
    Steve I - Ответить
  6. Apple AirPort Extreme Model A1354 Antenna Replacement, Antenna: шаг 6, изображение 1 из 1
    • Remove the metal casing by gently prying the logic board away with you hands.
    • This should be pretty easy, you already removed the screws holding these pieces together.
  7. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 7, изображение 1 из 2 Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 7, изображение 2 из 2
    • Turn the device so that the antenna to be replaced is facing you.
  8. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 8, изображение 1 из 1
    • Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
    • Using the screwdriver, unscrew the 2.5mm Phillips screw on the antenna.
  9. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 9, изображение 1 из 1
    • Turn the device over so that the antenna with the screw removed is still facing you.
  10. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 10, изображение 1 из 1
    • Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
  11. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 11, изображение 1 из 2 Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 11, изображение 2 из 2
    • Carefully peel back the clear yellow tape covering the cable of the antenna to be removed.
  12. Apple AirPort Extreme Model A1354 Antenna Replacement: шаг 12, изображение 1 из 1
    • Remove the antenna.
Заключение
4 участников успешно повторили данное руководство.
Brandon
Участник с: 04/02/12
387 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-2, Forte Spring 2012 Участник Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 членов
Автор 12 руководств
3 Комментариев
Where do you get a new antenna from?
jimholewka - Ответить
That's my question too. Where do we get a new antenna and wifi card to correct a poor signal?
jonathan - Ответить
How will I receive an answer? jonathan@baylis.ca
jonathan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 12,213
