Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
First start by peeling off the outer rubbery covering on the bottom of the device.
After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
It should make a click when it comes apart.
Remove the outer casing.
The exposed logic board should look like this.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
Turn the device so that the antenna to be replaced is facing you.
Using the screwdriver, unscrew the 2.5mm Phillips screw on the antenna.
Turn the device over so that the antenna with the screw removed is still facing you.
Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
Carefully peel back the clear yellow tape covering the cable of the antenna to be removed.
4 участников успешно повторили данное руководство.
