Apple AirPort Extreme Model A1354 Logic Board Replacement
Выберете то, что вам нужно
  1. Apple AirPort Extreme Model A1354 Logic Board Replacement, Outer Case: шаг 1, изображение 1 из 1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 2, изображение 1 из 1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 3, изображение 1 из 1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 4, изображение 1 из 3 Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 4, изображение 2 из 3 Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 4, изображение 3 из 3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 5, изображение 1 из 1
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Apple AirPort Extreme Model A1354 Logic Board Replacement, WiFi Card: шаг 6, изображение 1 из 1
    • Take the device out of the casing and orient it so that you can see the WiFi card.
  7. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 7, изображение 1 из 1
    • Wires come from the three antennas and connect on the outer edge of the WiFi card.
    • Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
    • Do this for the remaining two wires.
  8. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 8, изображение 1 из 1
    • There are two clips attached to the upper and lower ends of the WiFi card
    • CAUTION: For the following step, do not pull the clip after you have detached it. The clip is fragile and too much force may cause the clip to break.
    • Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
    • Do the same for the other clip.
  9. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 9, изображение 1 из 2 Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 9, изображение 2 из 2
    • Grasp the upper and lower ends of the WiFi card.
    • Carefully pull the WiFi card to the right.
    • CAUTION: Do not pull UP (towards yourself) on the WiFi card when removing. The card is on a track that only allows it to move left and right. Forcing the card to move in other directions may result in breaking the track.
    • Completely remove the WiFi card.
  10. Apple AirPort Extreme Model A1354 Logic Board Replacement, Battery: шаг 10, изображение 1 из 1
    • Remove the metal casing by gently prying the logic board away with you hands.
    • This should be pretty easy, you already removed the screws holding these pieces together.
  11. Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 11, изображение 1 из 3 Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 11, изображение 2 из 3 Apple AirPort Extreme Model A1354 Logic Board Replacement: шаг 11, изображение 3 из 3
    • Remove the battery by gently "shoving" it out with the plastic tool.
  12. Apple AirPort Extreme Model A1354 Logic Board Replacement, Logic Board: шаг 12, изображение 1 из 1
    • This is the "naked" logic board. You can order a new one and replace it by following the above steps in reverse order.
Заключение
3 участников успешно повторили данное руководство.
Brandon
Участник с: 04/02/12
387 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-2, Forte Spring 2012 Участник Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 18
За всё время: 8,676
