ΠΠ²Π΅Π΄Π΅Π½ΠΈΠ΅
This will show how to take apart the outer case of the device so repairs can be made.
ΠΠ½ΡΡΡΡΠΌΠ΅Π½ΡΡ
ΠΠ°ΠΏΡΠ°ΡΡΠΈ
ΠΠ΅ΡΠ°Π»ΠΈ Π½Π΅ ΡΠΊΠ°Π·Π°Π½Ρ.
First start by peeling off the outer rubbery covering on the bottom of the device.
After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
It should make a click when it comes apart.
Remove the outer casing.
The exposed logic board should look like this.
ΠΡΠΌΠ΅Π½ΠΈΡΡ: Π― Π½Π΅ Π²ΡΠΏΠΎΠ»Π½ΠΈΠ» ΡΡΠΎ ΡΡΠΊΠΎΠ²ΠΎΠ΄ΡΡΠ²ΠΎ.
2 ΡΡΠ°ΡΡΠ½ΠΈΠΊΠΎΠ² ΡΡΠΏΠ΅ΡΠ½ΠΎ ΠΏΠΎΠ²ΡΠΎΡΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ ΡΡΠΊΠΎΠ²ΠΎΠ΄ΡΡΠ²ΠΎ.
ΠΠ΄ΠΈΠ½ ΠΊΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠΉ
This guide also applies to model A1408.
