Введение
Replacing the back pad is necessary for future replacements for this device.
Выберете то, что вам нужно
Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
Use heat in areas where the glue is not loose enough.
To reassemble your device, follow these instructions in reverse order without using the hair dryer.
