Apple Airport Extreme Model A1408 Battery Replacement
Выберете то, что вам нужно
  1. Apple Airport Extreme Model A1408 Battery Replacement, Back Pad: шаг 1, изображение 1 из 1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Battery Replacement: шаг 2, изображение 1 из 1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
  3. Apple Airport Extreme Model A1408 Battery Replacement, Outer Case: шаг 3, изображение 1 из 2 Apple Airport Extreme Model A1408 Battery Replacement, Outer Case: шаг 3, изображение 2 из 2
    • After removing the back pad, unscrew the five 5 mm Phillips #00 screws in the large, deep holes in the plastic casing. The plastic casing should come off easily after removing all the screws.
    • When installing the plastic back cover, ensure the lip is aligned with the ports on the back of the device.
  4. Apple Airport Extreme Model A1408 Battery Replacement: шаг 4, изображение 1 из 2 Apple Airport Extreme Model A1408 Battery Replacement: шаг 4, изображение 2 из 2
    • Insert a narrow plastic opening tool into one of the notches. Apply moderate force to pull the metal casing from the plastic outer casing. You can use the rim of the outer case as leverage. You should hear a click when the metal casing detaches.
    • After you hear the click, remove the inner metal case from the outer case using your hands. It should not take very much force.
  5. Apple Airport Extreme Model A1408 Battery Replacement, Battery: шаг 5, изображение 1 из 2 Apple Airport Extreme Model A1408 Battery Replacement, Battery: шаг 5, изображение 2 из 2
    • Wedge the tip of a plastic opening tool between the battery and the securing clip. Pop the battery out using sufficient leverage.
Заключение
3 участников успешно повторили данное руководство.
Taiki Murakami
Участник с: 10/14/14
176 Репутация
1 руководство автора
Команда
Cal Poly, Team 10-37, Amido Fall 2014 Участник Cal Poly, Team 10-37, Amido Fall 2014
CPSU-AMIDO-F14S10G37
4 членов
Автор 12 руководств
3 Комментариев
Just Wondering, What is the Nomenclature , size and or specs of the internal battery A-1408 5th Generation have tried to find schematics to order a new
One but no dice. Bye the way you guys rock thank you so much, you may
E-Mail me at jcp512644@gmail.com
Jahn Peltz - Ответить
The battery is BR2330 3V. That is 23mm diameter and 3mm thickness.
Martin Krencey -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 4,035
