Apple Cinema Display M8149 LCD Screen Replacement
Выберете то, что вам нужно
  1. Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: шаг 1, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: шаг 1, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: шаг 1, изображение 3 из 3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
    Mine had hex head screws instead of Phillips head.
    Bill Greene - Ответить
  2. Apple Cinema Display M8149 LCD Screen Replacement: шаг 2, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 2, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 2, изображение 3 из 3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
    AND: Shall we mention right here, there is a small white connector leading to the display's POWER button that should be disconnected to slide the back plate off.
    spudmcat - Ответить
    These screws too were hex head, not PH2, on my display.
  3. Apple Cinema Display M8149 LCD Screen Replacement: шаг 3, изображение 1 из 2 Apple Cinema Display M8149 LCD Screen Replacement: шаг 3, изображение 2 из 2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
    Here and on the next step you’ll m
    need a PH 2 screwdriver
    dietrichbatista - Ответить
  4. Apple Cinema Display M8149 LCD Screen Replacement: шаг 4, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 4, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 4, изображение 3 из 3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
    There are 2 Phillips screws at the center top and center bottom that need to be removed as well. They are parallel to the work surface if the screen is flat. The control board must be lifted slightly to access the screws. There's also a clip holding the disconnected power connector to the mechanisms below.
    About This Matt - Ответить
  5. Apple Cinema Display M8149 LCD Screen Replacement: шаг 5, изображение 1 из 2 Apple Cinema Display M8149 LCD Screen Replacement: шаг 5, изображение 2 из 2
    • Gently lift the large metal cover which spans across the back of the whole display.
  6. Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: шаг 6, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: шаг 6, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: шаг 6, изображение 3 из 3
    • Carefully remove the two tape plugs on either side of the control board using a spudger.
  7. Apple Cinema Display M8149 LCD Screen Replacement: шаг 7, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 7, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 7, изображение 3 из 3
    • Pull the previously removed tape out from the metal box with your hand.
    • Peel back the white plastic cover located on the tape plug and unplug the tape plug on the right side of the unit using the spudger.
  8. Apple Cinema Display M8149 LCD Screen Replacement: шаг 8, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 8, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement: шаг 8, изображение 3 из 3
    • Unscrew the four screws (4.79x2.33mm) on the metal box using the Phillips #2 screwdriver.
    • Lift the metal cover off to reveal a circuit board.
    • Remove the two terminal screws (4.79x2.34mm) using the Phillips #2 screwdriver.
  9. Apple Cinema Display M8149 LCD Screen Replacement: шаг 9, изображение 1 из 2 Apple Cinema Display M8149 LCD Screen Replacement: шаг 9, изображение 2 из 2
    • Remove the terminal cover.
    • Remove the circuit board from the right side of the unit by gently lifting it out.
  10. Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: шаг 10, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: шаг 10, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: шаг 10, изображение 3 из 3
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
  11. Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: шаг 11, изображение 1 из 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: шаг 11, изображение 2 из 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: шаг 11, изображение 3 из 3
    • Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
Заключение
3 участников успешно повторили данное руководство.
Curtis Musashi
Участник с: 04/01/11
152 Репутация
1 руководство автора
Команда
Cal Poly, Team 10-41, Forte Spring 2011 Участник Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 членов
Автор 12 руководств
2 Комментариев
hello! where can i buy lcd screen for m8149?
jgill1971 - Ответить
Does anyone know where to get an inexpensive LCD replacement. Mine went primarily magneta except for the outer edges after zapping the pram?! Totally bummed as I bought a DVI to ADC power source and now the monitor is useless in it’s current state. C’est la vie!
le_grand - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 8,301
