Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This repair will need:
A T-8 or T-6 Torx Screwdriver.
Выберете то, что вам нужно
Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
Removing both ribbon cables from the motherboard will leave the clamps like so.
From here you can access the logic board, hard drive, and floppy drive.
Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
2 участников успешно повторили данное руководство.
