Введение
This guide will be teaching you how to easily replace the modem in your computer.
Запчасти
Никакие детали не требуются.
  1. Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Pull the keyboard ribbon vertically from the logic board to release connection.
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Your computer should look approximately like this.
    • Your computer should look approximately like this.
  4. Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Pull the PRAM battery cable vertically upward to disconnect it.
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
  7. Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
  8. Lift up the heat sink unit from the left side and remove.
    • Lift up the heat sink unit from the left side and remove.
  9. Lift the processor on the right side and pull directly up.
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
  10. After removing the RAM, your laptop should now look like this.
    • After removing the RAM, your laptop should now look like this.
  11. Remove the single black Torx screw from the modem.
    • Remove the single black Torx screw from the modem.
    • Remove the black rectangle that is being held on by the one Torx screw.
  12. Using your fingers, lift the modem from the socket it is plugged into.
    • Using your fingers, lift the modem from the socket it is plugged into.
  13. Disconnect the cable that is attached to the end of the modem to remove the modem.
    • Disconnect the cable that is attached to the end of the modem to remove the modem.
Заключение
Byron Hoefer
Участник с: 18.04.2011
70 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-2, Regan Spring 2011 Member of Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 962
