Apple Studio Display M7649 ADC Cable Replacement
Выберете то, что вам нужно
  1. Apple Studio Display M7649 ADC Cable Replacement, Stand: шаг 1, изображение 1 из 2 Apple Studio Display M7649 ADC Cable Replacement, Stand: шаг 1, изображение 2 из 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 ADC Cable Replacement, Panels: шаг 2, изображение 1 из 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 ADC Cable Replacement: шаг 3, изображение 1 из 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 ADC Cable Replacement: шаг 4, изображение 1 из 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 ADC Cable Replacement, Metal EMI Shield: шаг 5, изображение 1 из 1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 ADC Cable Replacement: шаг 6, изображение 1 из 1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 ADC Cable Replacement: шаг 7, изображение 1 из 2 Apple Studio Display M7649 ADC Cable Replacement: шаг 7, изображение 2 из 2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 ADC Cable Replacement, USB Port: шаг 8, изображение 1 из 1
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Apple Studio Display M7649 ADC Cable Replacement: шаг 9, изображение 1 из 1
    • Remove the cable from the logic board that is connecting the USB port.
  10. Apple Studio Display M7649 ADC Cable Replacement: шаг 10, изображение 1 из 1
    • Remove the USB port
  11. Apple Studio Display M7649 ADC Cable Replacement, ADC Cable: шаг 11, изображение 1 из 1
    • Remove these four screws holding down the base of the swing arm to the display and remove it
  12. Apple Studio Display M7649 ADC Cable Replacement: шаг 12, изображение 1 из 1
    • Remove the four screws holding down the ADC cable to the display
  13. Apple Studio Display M7649 ADC Cable Replacement: шаг 13, изображение 1 из 1
    • Remove the three connections that connects the ADC assembly to the logic board and screen
  14. Apple Studio Display M7649 ADC Cable Replacement: шаг 14, изображение 1 из 1
    • Remove and replace the ADC cable assembly.
Заключение
3 участников успешно повторили данное руководство.
Andrew Tsao
Участник с: 01/19/10
186 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 3-20, Maness Winter 2010 Участник Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 членов
Автор 15 руководств
Один комментарий
What are the two red wires and two black wires ?
Cali Red - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 15
За всё время: 2,794
