Введение
Replacing the inverter, a common cause for what looks to be a loss of backlight.
Выберете то, что вам нужно
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
Rotate the display so the legs of the display are now facing you
Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
Now locate and remove the lone Phillips screw holding the EMI shield to the display
Now that the screw has been removed, slide the panel towards your body and lift it out.
Remove these five cables connection the inverter to the backlights and logic board.
5 человек успешно провели ремонт по этому руководству.
