Apple TV 1st Generation Lower Case Replacement
Выберете то, что вам нужно
  1. Apple TV 1st Generation Lower Case Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Apple TV 1st Generation Lower Case Replacement: шаг 2, изображение 1 из 1
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. Apple TV 1st Generation Lower Case Replacement: шаг 3, изображение 1 из 1
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. Apple TV 1st Generation Lower Case Replacement: шаг 4, изображение 1 из 2 Apple TV 1st Generation Lower Case Replacement: шаг 4, изображение 2 из 2
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
Заключение
3 участников успешно повторили данное руководство.
CCarvalho
Участник с: 11/08/09
283 Репутация
1 руководство автора
Команда
Cal Poly, Team 18-5, Maness Fall 2009 Участник Cal Poly, Team 18-5, Maness Fall 2009
CPSU-MANESS-F09S18G5
5 членов
Автор 6 руководств
Один комментарий
This guide may make more sense as a teardown, since its not really showing any repairs or replacements.
Alex Jansen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 8,407
