Apple TV 2nd Generation Power Supply Replacement
Выберете то, что вам нужно
  1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: шаг 1, изображение 1 из 2 Apple TV 2nd Generation Power Supply Replacement, Power Supply: шаг 1, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Metal Spudger
    $2.99
    Купить
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
  2. Apple TV 2nd Generation Power Supply Replacement: шаг 2, изображение 1 из 3 Apple TV 2nd Generation Power Supply Replacement: шаг 2, изображение 2 из 3 Apple TV 2nd Generation Power Supply Replacement: шаг 2, изображение 3 из 3
    Phillips #1 Screwdriver
    $5.49
    Купить
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  3. Apple TV 2nd Generation Power Supply Replacement: шаг 3, изображение 1 из 2 Apple TV 2nd Generation Power Supply Replacement: шаг 3, изображение 2 из 2
    Купить
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  4. Apple TV 2nd Generation Power Supply Replacement: шаг 4, изображение 1 из 2 Apple TV 2nd Generation Power Supply Replacement: шаг 4, изображение 2 из 2
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
Заключение
Еще один человек закончил это руководство.
Deanna Rice
Участник с: 09/28/17
261 Репутация
Автор 2 руководств
Команда
University of Maine, Team S1-G2, Diaz Fall 2017 Участник University of Maine, Team S1-G2, Diaz Fall 2017
UMAINE-DIAZ-F17S1G2
4 членов
Автор 4 руководств
2 Комментариев
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Ответить
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 24
За всё время: 1,773
