Apple TV 2nd Generation Power Supply Replacement
Выберете то, что вам нужно
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  1. Apple TV 2nd Generation Power Supply Replacement: шаг 4, изображение 1 из 2 Apple TV 2nd Generation Power Supply Replacement: шаг 4, изображение 2 из 2
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
Заключение
Еще один человек закончил это руководство.
Deanna Rice
Участник с: 09/28/17
261 Репутация
Автор 2 руководств
Команда
University of Maine, Team S1-G2, Diaz Fall 2017 Участник University of Maine, Team S1-G2, Diaz Fall 2017
UMAINE-DIAZ-F17S1G2
4 членов
Автор 4 руководств
2 Комментариев
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Ответить
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 1,560
