Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
Disconnect the power supply connector from the logic board with a spudger.
Before you remove completely the power supply, unscrew the T5 screws on each side of the socket.
You may now be able to remove the power supply with a spudger.
The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
14 участников успешно повторили данное руководство.
11 Комментариев
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
Where? I need on badly! Can you send me / Post here a link?
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
