Введение
In this guide we will disassemble and remove the power supply from an Apple TV 4K
Выберете то, что вам нужно
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
Four 10 mm screws
Lift and remove the heat sink assembly from the device.
Use plastic spudger to pull up on all three antenna connectors to remove them.
Remove rubber piece from front side of device.
Unscrew the following screws holding the logic board in place using the T7 Torx:
Two black 3 mm screws
Two silver 4 mm screws
Use a spudger to pry up logic board. Try lifting it up from the front side.
Remove logic board and set aside.
Use a T7 Torx to remove the screws:
Five 5mm screws
Carefully flip the device upside down to remove the logic board/power supply mount.
Also remove the Two T6 Torx screws from the AC Power Connector. This will help in removal of the Power Supply.
Undo the latch connecting the power connector to the power supply.
Feed the wire though the logic board/power supply mount.
Using a T-7 Torx unscrew the two silver screws.
Two 4mm silver screws
Use a screwdriver with a T-7 Torx bit to remove the following screws:
Five black 3mm screws
lift the power supply out of it's mount.
Use a T6 Torx to remove the two screws holding the power supply connector in place. Pull the power connector away from the case.
Two 3mm screws
10 человек успешно провели ремонт по этому руководству.
8 Комментариев
Please, explain the 12V power supply topic: does that means it can be installed in a car or a boat out of the box?
power supply available at Ali Express
https://de.aliexpress.com/item/100500295...
Neue Original Power Board Supply Unit PA-1120-9A Universal ADG023 für Apple TV 4K 5th Generation A1842 Modell
I bought the new power supply from the above link and it did arrive even faster than they said it would. Unfortunately, I reassembled my Apple TV and it's still not working. No light. No signal. It could be that it was the power connector, logic board and not the power supply all along I suppose. I did of course already rule out the power cord and the hdmi cable. Also I did manage to give myself a small shock on disassembly so maybe I fried something. I'm curious if there's a straight forward way to test which part is bad using a voltage meter. It seems that if I could have done that in the first place it might have saved me a lot of hassle.
There are three clips on each side - short after the beginning of the rounding on each side, and one middle.
The bottom panel is approx 5mm in height and a little bit flexible.
hackgreti - Ответить
