Apple TV 4th Generation Logic Board Replacement
Выберете то, что вам нужно
  1. Apple TV 4th Generation Logic Board Replacement, Remove the Heatsink: шаг 1, изображение 1 из 3 Apple TV 4th Generation Logic Board Replacement, Remove the Heatsink: шаг 1, изображение 2 из 3 Apple TV 4th Generation Logic Board Replacement, Remove the Heatsink: шаг 1, изображение 3 из 3
    • Unplug all cables from the Apple TV before disassembly and flip the device over.
    • Using the widest plastic opening tool, force its sharp end into the seam between the Apple TV's bottom plate and its outer casing. Starting on the side with the ports, insert the tool so its tip is angled upward when leverage is applied.
    • Pry the bottom plate away from the case, starting with the edge closest to the bottom of the apple. Work your way around the plate until all clips are disconnected.
    • With the plastic clips free, lift the bottom plate.
    • The bottom plate is held in place by plastic clips that correspond to indentations on the bottom plate. These indentations break easily, as evidenced by the third photo (breakage will not prevent the plate from going back on). To avoid breakage, apply force at the location of these clips, starting from the middle.
  2. Apple TV 4th Generation Logic Board Replacement, Removing the Cap: шаг 2, изображение 1 из 3 Apple TV 4th Generation Logic Board Replacement, Removing the Cap: шаг 2, изображение 2 из 3 Apple TV 4th Generation Logic Board Replacement, Removing the Cap: шаг 2, изображение 3 из 3
    • Remove the five (5) 7mm T7 Torx screws.
    • Pull upward on the edges of the shield.
    • Avoid disturbing the square of gray thermal paste centered on the opposite side of the heatsink/EMI shield during removal.
  3. Apple TV 4th Generation Logic Board Replacement, Logic Board: шаг 3, изображение 1 из 2 Apple TV 4th Generation Logic Board Replacement, Logic Board: шаг 3, изображение 2 из 2
    • Remove the 4mm T7 Torx screw.
    • Remove the 5mm T7 Torx screw and its accompanying washer.
    • The silver screw is accompanied by a washer that is easily lost.
  4. Apple TV 4th Generation Logic Board Replacement: шаг 4, изображение 1 из 2 Apple TV 4th Generation Logic Board Replacement: шаг 4, изображение 2 из 2
    • Use the plastic opening tool to tip the board upward.
    • Avoid disturbing the square of gray thermal paste centered on top of the power supply/heatsink during removal.
Заключение
4 участников успешно повторили данное руководство.
Eric Arnold
Участник с: 09/28/17
326 Репутация
1 руководство автора
Команда
University of Maine, Team S1-G1, Diaz Fall 2017 Участник University of Maine, Team S1-G1, Diaz Fall 2017
UMAINE-DIAZ-F17S1G1
4 членов
Автор 6 руководств
2 Комментариев
Can a replacement logic board be bought online ? What is the part number ?
Thank You
Karine-Johanne - Ответить
Where can I find a replacement logic board?! I can’t seem to find a website with one anywhere!
David Sein - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 9
За последние 30 дней: 61
За всё время: 4,238
