Apple TimeCapsule A1355 opening for repair
  1. Apple TimeCapsule A1355 opening for repair, cutting the rubber: шаг 1, изображение 1 из 3 Apple TimeCapsule A1355 opening for repair, cutting the rubber: шаг 1, изображение 2 из 3 Apple TimeCapsule A1355 opening for repair, cutting the rubber: шаг 1, изображение 3 из 3
    • all measures are with the rubber still on. and it stays on.
    • first you take a cutter and cut little squared or circles or what you prefer into the rubber. and then, f.e with the screwdriver tear of the rubber on the incicion you just did.
    • there are exact measures in millimetres. I recommend to turn the TimeCapsule with connections facing you and then start from the lower left corner.
    • fyi: 1 inch = 25,4 mm, 1 feet = 304,8 mm
    • Note: the green lines indicate that the screws are in alignment with each other.
    • Note: the different color circles indicate screws. I found only the 1. gen TimeCapsule sometimes be having the purple screws. with the 2.,3.,4. Generation I never found the purple ones.
  2. Apple TimeCapsule A1355 opening for repair, different generations: шаг 2, изображение 1 из 1
    • the first generation is sometimes different. I had ones where in the purple markers are screws . sometimes they are reveted from the other side, and must not be removed.
    • the 2,3,4 generation have almost the same screws. sometimes the brown ones dont exist.
  3. Apple TimeCapsule A1355 opening for repair, opening the box: шаг 3, изображение 1 из 1
    • turn the TimeCapsile 90D clockwise.
    • then get something where you can lean on the opened but still connected part. (in my case I used another time capsule for it)
    • then carefully open the lid to the left. and carefully put it aside like shown on the picture
    • after that you can do inside whatever you desire. in my case I took out the hard drive
  4. Apple TimeCapsule A1355 opening for repair: шаг 4, изображение 1 из 1
    • if you are nerdy or have too much time on your hand, you can keep the cut-out rubber pieces and after replacement you can glue the right parts back in.
    • note: nobody sees the bottom of the TimeCapsule in general.
    • so I did not.
    • ENJOY
Заключение
6 человек успешно провели ремонт по этому руководству.
Martin David
Участник с: 05/27/13
314 Репутация
1 руководство автора
Команду
LGBTQ Technicians Участник LGBTQ Technicians
Community
33 членов
Автор 96 руководств
Один комментарий
Thank you for detailed explanation of the screws positions.
I successfully replaced my faulty hard drive to the new one.
Artur Pędziwilk - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 6
За последние 7 дней: 26
За последние 30 дней: 102
За всё время: 6,134
