Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Unfortunately, opening up your Apple Watch may damage the Force Touch sensor, which also serves as a gasketing seal. The sensor is made up of two layers, glued together. These layers may separate when you open your watch, compromising its seal after reassembly. If this happens, you'll need to repair or replace the sensor before reassembling your watch.
Выберете то, что вам нужно
Before starting repairs, take your watch off the charger and power it down.
Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
Инструмент, используемый на этом этапе:Safety Glasses$3.19
Place the curved section of the blade in the gap between the glass and case on the lower edge of the watch face, and press firmly straight down into the gap.
When the glass has lifted, gently rotate the knife down, opening the gap more by pushing the glass up.
Once you've opened the gap enough, insert the tip of an opening pick under the glass.
Slide the pick along the bottom edge to separate adhesive holding the screen to the case.
Roll the opening pick up the side of the button side of the watch, gently pushing in to separate the adhesive and widening the gap as you go.
Work the pick around the top right corner, and roll it along the top edge of the screen.
Continue working the pick around the perimeter of the screen, rolling down along the left side to cut the last of the adhesive.
While holding the first pick in place, use a second to check that all of the adhesive is separated around the entire perimeter of the screen.
Pry slightly up on the right side of the screen, to free it from any remaining adhesive.
Pry up on the left to free it as well—but do not attempt to remove the screen as it is still held in place by two cables.
The top layer of the sensor may be adhered to the back of the screen—if so, push it back down and separate it.
Lift the screen up and shift it to the left, minding the display data and digitizer cables.
Place the watch on an elevated surface, at least 1/2" or 1 cm tall—a small box or the edge of a book will work great. This will allow the screen to hang down vertically and give better access to the battery.
Use scissors to cut one of your opening picks to about the width of the battery. Try not to leave any sharp corners.
Insert the modified pick between the right side of the battery and the case.
Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
On the larger (42 mm) models, it's possible to accidentally pry at the system board underneath the battery. Insert the pick only far enough to get underneath the battery, not the system board.
If needed, apply a little high concentration isopropyl alcohol (90% or greater) around and under the battery to help weaken the adhesive.
Hold the battery up and out of the way, to expose the battery cable connector.
Use a plastic opening tool, prying against the bottom of the case to separate the battery cable connector from the watch's battery cable.
Remove the battery from the watch.
Fold the screen up and over to the right, to expose the cables underneath.
Use a plastic opening tool to flip the bracket toward the display and up from the speaker.
Steady the bracket from the left side using your fingers or tweezers.
At the same time, insert a small (1 mm) flathead screwdriver under the tiny tab on the right.
Finally, place one finger behind the tab, and pinch the bracket hard between your finger and the screwdriver to detach the cover.
Grab the cover with your tweezers and slide it toward the top of the watch to free the final slotted tab, and remove the cover.
Carefully pry up to disconnect the display data and digitizer cables.
Remove the display.
Use a Y000 driver to remove the single tri-point screw securing the Force Touch sensor connector cable.
Use a plastic opening tool to flip the Force Touch sensor cable connector straight down, disconnecting it.
Microwave your iOpener for another 30 seconds, and apply it to the front of the watch case to soften the adhesive securing the Force Touch sensor.
Use a plastic opening pick and tweezers to remove the Force Touch sensor from the case.
Use tweezers to peel up any adhesive left behind on the lower case.
Clean all traces of adhesive (and broken glass, if any) thoroughly from the case before re-sealing your watch. Scour the case using the tip of an opening tool or spudger wrapped in a lint-free cloth or coffee filter, along with a little isopropyl alcohol (90% concentration or greater).
Use a plastic opening tool to scrape off the old adhesive around the edge of the screen. If possible, peel off larger pieces using tweezers.
Thoroughly clean the area under the adhesive with isopropyl alcohol.
Set your new Force Touch sensor face-down (with the connector pins facing away from you).
Peel off and discard the first protective liner, exposing the adhesive underneath.
With the exposed adhesive facing down, carefully align the Force Touch sensor and place it into the watch case.
Be sure to properly orient it, with the connector in the lower left corner, facing up.
Gently but firmly press the Force Touch sensor into place all around the perimeter of the watch case.
Use tweezers to fold the Force Touch sensor cable connector back up onto its socket.
Then use a plastic opening tool to press the cable connector into the socket.
Replace the Y000 tri-point screw securing the Force Touch sensor connector cable.
Use a plastic opening tool to reconnect the display data and digitizer cable connectors.
Set the display connector bracket cover in place and slide it lengthwise to secure the large slotted tab at one end.
Press down on the cover to click the two smaller tabs at the other end into place.
Line the battery connector up with its mate on the cable inside the watch body.
Use tweezers to press the two connectors together.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
If needed, try re-using the existing adhesive to secure the battery. Alternatively, try a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
Rotate the battery down into its slot, and press it into position.
Press the battery down against the system board to re-adhere it in place.
Use tweezers to peel up the adhesive liner.
Peel the liner up halfway, then snip it with scissors so you can peel the rest off without it snagging on the display.
Move the screen back to the right, folding the display data and digitizer cables neatly.
Center the screen over the case and press it down firmly onto the adhesive.
For best results, detach the watch band and wrap a couple rubber bands around the Apple Watch's case to help the adhesive bond correctly.
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
236 участников успешно повторили данное руководство.
43 Комментариев
I can't stress enough how important it is to not flex the digitizer ribbon cable. A cracked ribbon cable will necessitate replacing the entire lcd.
This is a Fact. It happened to me when the whole rig hit the floor lol
If there is a new induction frame - do not use double-sided adhesive tape.
How can I tell if there is a new induction frame?
By Induction Frame, what do you mean, exactly?
