Apple Watch Series 3 Adhesive Replacement
Выберете то, что вам нужно
  1. Apple Watch Series 3 Adhesive Replacement, Cleaning the gasket: шаг 1, изображение 1 из 2 Apple Watch Series 3 Adhesive Replacement, Cleaning the gasket: шаг 1, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Adhesive Cleanup Kit (Set of 12)
    Купить
    • Apply a little bit of isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the adhesive leftovers on top of the force touch gasket.
    • To remove the adhesive on the side where the display cables are running, fold down the display and carefully pull it away from the frame so there's enough space.
    I bought 6 adhesive strips expecting to foul up some. I tried following this procedure on three of the sets, but on each set I ended up with one corner not quite long enough to seat properly. On the fourth set I altered the procedure and it finally worked the first time.
    1. Take off the screen. Yes I know, but do it anyway.
    2. Take off only the blue adhesive around the periphery. Do not remove center area.
    3. Place sticky side on force gasket. Seems small, but fit perfectly.
    4. Remove entire inner rectangular portion of adhesive strip
    5. Replace screen
    6. Re-Attach battery
    7. Follow rest of procedure
    marilyntlinton - Ответить
    The isopropyl alcohol can only remove so much of the old adhesive. After the first pass with the q-tip use an iFixit Opening Tool to carefully scrape off the old adhesive. There is always some left on the case.
    Vangelis Angelakis - Ответить
  2. Apple Watch Series 3 Adhesive Replacement, Cleaning the display: шаг 2, изображение 1 из 2 Apple Watch Series 3 Adhesive Replacement, Cleaning the display: шаг 2, изображение 2 из 2
    • Flip the Apple Watch upside down so the display lays flat while lifting up the case.
    • Remove the leftovers on the back of the display.
  3. Apple Watch Series 3 Adhesive Replacement, Applying the new adhesive: шаг 3, изображение 1 из 1
    • Use a pair of tweezers to carefully remove replacement adhesive with the blue protective film from the backing paper.
    Be sure to buy two, three or even more replacement adhesive strips, because depending on the batch or brand, most of them can’t be separated easily, they deform and then they are next to useless.
    @iFixit - Guys check the adhesives you are sending to people. The Tesa ones are simply a nightmare to use.
    Agreed! The strip is EXTREMELY challenging to get off the paper/plastic it comes in - I recommend a very sharp ‘Xacto’, or scalple blade to trim the paper & plastic film (carefully) to allow for the very thin & easily damaged strip from the packaging - let alone getting it place. Vangelis’ adice is sound advice. I had to order two more… (wish me luck)
    Jeff Goodall - Ответить
    Thank you both for the heads up! The Tesa brand adhesive was super finicky (my tab broke off pretty early on) but was able to recover with minimal deformation with a blade to remove the unnecessary plastic.
    Felipe Agurto - Ответить
  4. Apple Watch Series 3 Adhesive Replacement: шаг 4, изображение 1 из 2 Apple Watch Series 3 Adhesive Replacement: шаг 4, изображение 2 из 2
    • Hold the replacement adhesive diagonally to thread it over the display.
    • Slightly tilt the display forward so you can align the adhesive with the frame.
    • Position the replacement adhesive on top of the force touch gasket and use the pointed end of a spudger to move and press it into place.
    Den Klebestreifen zu positionieren ist extrem schwer. Teils wegen unzureichender Passgenauigkeit des Klebestreifens, teils weil er ja schon einseitig klebt. Es ist auf jeden Fall hilfreich das AppleWatch-Gehäuse vorher zu fixieren. Ich werde diese Methode nicht ein weiteres mal anwenden, sondern das nächste mal flüssigen Kleber aus der Tube (E-8000 oder vergleichbares) verwenden.
    BjoernImNetz - Ответить
    These things are garbage! I’ve replaced the adhesive on 4-5 Apple watches with various cheap Amazon adhesive products. The tab came off on two different ifixit adhesive kits. The first one the white backer would come all the way off the adhesive, so it was worthless. The second one either stretched or was made too long.
    Don’t waste your money. Quality is poor
    the.thams - Ответить
  5. Apple Watch Series 3 Adhesive Replacement: шаг 5, изображение 1 из 1
    • Reconnect the battery as seen in the replacement guide you came from.
    • Remove the protective film from the adhesive.
    Don’t expect the adhesive strip to follow the edges of the watch’s case. If you try to fit it on the edges on one side, you may end up coming up short on the other, as the above image illustrates. Just try to place it slightly off the edges. It will be ok.
  6. Apple Watch Series 3 Adhesive Replacement: шаг 6, изображение 1 из 1
    • Align the screen and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive you can use an iOpener to warm up the display. Then apply some pressure for a few hours (placing it under one or two heavy books overnight might be a way).
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
    Buy two clamps, thank me later. Books are good but trust me the clamps are way better. Also expect the screen to wobble ever so slightly after, since the adhesive seems to be a bit elastic in nature.
    Avoid hot or even warm showers to avoid causing the screen to detach from the adhesive.
Финишная черта
29 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
117 217 Репутация
Автор 188 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 519 руководств
7 Комментариев
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
Ryan Hoover - Ответить
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Kevin Male - Ответить
Yes mine was also larger than the adhesive seal that is advertised here.
Nicholas Goldsworthy - Ответить
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
iRepairMan - Ответить
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
I agree that the adhesive is too small for the series 3 case. Also as noted, you need to use the blade from the kit to carefully go all around cutting the thin strip away from the center piece. Remove the center piece completely first! Putting it in place with the back side backing removed is very difficult! I think if there is a next time that I will remove the backside backing after I have put it in place. Going over the lens and past the cables is impossible without it touching something.
Because of these issues I think I would call this install difficulty HIGH.
Bill Auerbach - Ответить
Gasket too big for 42mm watch. Useless.
tom.mckerrow - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 47
За последние 30 дней: 267
За всё время: 25,061
