Apple Wireless Keyboard Battery Replacement
Выберете то, что вам нужно
  1. Apple Wireless Keyboard Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Use a coin to remove the battery compartment cover.
    What if solidly stuck? No way then to change battery it needs active.
    Sherry Lowry - Ответить
  2. Apple Wireless Keyboard Battery Replacement: шаг 2, изображение 1 из 2 Apple Wireless Keyboard Battery Replacement: шаг 2, изображение 2 из 2
    • Slide the two (three on the previous generation) replacement AA batteries into the battery compartment. Verify the positive and negative terminals are facing the correct orientation.
    Question-how can I identify age of keyboard? I have it 7+ Year’s. Keyboard isn’t responding. Trying to change Batteries-I am able to ck 2 Batteries which are chgd. But it looks like it has another one but I can not get it out….any suggestions?
    Carol Ann - Ответить
    HELP ME PLEASE
    Carol Ann
Заключение
35 участников успешно повторили данное руководство.
rab777hp
Участник с: 11/17/09
20 333 Репутация
Автор 3 руководств
Команда
OPEN Участник OPEN
Community
82 членов
Автор 25 руководств
5 Комментариев
This works great - as long as the batteries inside did not leak and create a permanent seal for the cap. I managed to get the keyboard working again by removing the batteries through the electronics compartment (remove grey center cover, slide electronics out). It did take some effort (including driving a screw into the stuck battery and yanking it out with pliers) to remove the stuck batteries and all the remains of the leakage, but I ended up with a working keyboard. Only thing is that I need to use the 'backdoor' every time my batteries need replacing, since the battery cover is permanently sealed...
Otto - Ответить
Also have a perma sealed battery cover. Poured vinegar in from middle and let soak over night. Wanna drill into coin slot to try and remove cover but need to get batteries out first. Can I just remove the one screw from logic board and disconnect ribbon cable, to have it slide out the power button end? How careful w cable? Looks like it has 2 tiny clips, do these need to be addressed or can I just pry it off?
William Shouse -
Warm the area where battery screw cover is in a stream of hot water from the faucet. Be careful not to get water into the keyboard or keys. The warmth will sometimes expand the aluminum enough to loosen the screw cover. Worked for mine.
Greg M - Ответить
Thanks!
worked well. Had to push old battery out from electronics cover area. Keyboard working again :)
tankapoet - Ответить
It’s possible, but how can I get it? I am in somali country please help me
saalix49 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 112
За последние 30 дней: 526
За всё время: 98,029
