Apple Wireless Keyboard Logic Board Replacement
Выберете то, что вам нужно
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: шаг 1, изображение 1 из 2 Apple Wireless Keyboard Logic Board Replacement, Logic Board: шаг 1, изображение 2 из 2
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: шаг 2, изображение 1 из 1
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: шаг 3, изображение 1 из 3 Apple Wireless Keyboard Logic Board Replacement: шаг 3, изображение 2 из 3 Apple Wireless Keyboard Logic Board Replacement: шаг 3, изображение 3 из 3
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: шаг 4, изображение 1 из 1
    • Keeping the connection cable, push out the logic board's placement
    On some recent version of the keyboard, there's a plastic pin under the white logic board plastic holder, keeping the whole thing in position in the aluminium tube.
    You may have to pull slightly upward while pushing the logic board out of the tube to disengage the plastic pin.
    Kuf - Ответить
  5. Apple Wireless Keyboard Logic Board Replacement: шаг 5, изображение 1 из 1
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: шаг 6, изображение 1 из 1
    • Remove the logic board from the placement
Заключение
20 участников успешно повторили данное руководство.
Nicola
Участник с: 11/14/13
638 Репутация
1 руководство автора
9 Комментариев
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - Ответить
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - Ответить
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - Ответить
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - Ответить
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - Ответить
Great, now my Keyboard work thanks a lot!!!!!!!!
Maurizio - Ответить
My keyboard empties a fully loaded set of batteries in 1 day, anybody had an idea wat it could be?
Wesley Looy - Ответить
I bought used keyboard. It empties a set of batteries in less then a day. Plus it looses connections. Any ideas what this is?
koncan - Ответить
Hello! My keyboard has some keys that stopped working: delete, return, r-shift, caps lock, r-option, tab. The rest of the keys work fine. Any suggestions?
Mariano Belgrano - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 95
За всё время: 48,123
