Введение
This guide details how to replace the front panel and speaker connections of the Apple iPod Hi-Fi speaker system.
While following this guide, be sure to be careful of the protective wrapping around the interior components because the wrapping is made of small fibers that can make a large mess.
Выберете то, что вам нужно
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Pry out the large speaker with a metal spudger around the edge.
Remove the speaker slowly from its socket with your hands.
Press down on the tab and pull out with your hands to remove the cable connecting the large speaker from the rest of the unit.
Pull the large speaker completely out and set aside.
Pull the entire front assembly off by prying it up with the spudger and lifting the assembly off with your hands towards the top of the Hi-Fi.
Remove the clips for the remaining two speakers by repeating step 6.
Remove the last connection that connects the speakers to the power box.
Remove the front panel completely.
7 участников успешно повторили данное руководство.
4 Комментариев
Hi, I would like to know where to purchase replacement speakers for the Apple HiFi. TIA
Hi whehe can i find a replacement bass speaker ??
Yo necesito la fuente de poder de ese equipo, por favor si alguien lo tiene me escribe a: rolando.chungag@gmail.com
